Turtle_n_Peeps
Dec 05, 2015Explorer
There is several problems with "depending" on electronic sway control to control sway.
One is, as Bryan already mentioned is overheated trailer brakes. If you have a poorly designed or poorly loaded trailer that wants to sway and you have one of these systems on it, it can turn on the trailer brakes several times a second. I think you can imagine what that is going to do for trailer brake heat.
Two is trailer brake wear. If you have your trailer brakes on 50% of the time I think you can also imagine what that will do for trailer brake wear. :E
Three is horrid fuel mileage. Yes, you have your trailer brakes on 50% of the time you can imagine what that is going to do for you mileage. :E
These systems are like being fat and going to a doctor and wanting a pill to make you thinner. It's best just to fix the problem that causes the sway in the first place rather than go with Band-Aid systems.
Looking for advice before your next adventure? Look no further.25,209 PostsLatest Activity: Aug 28, 2026
