Our RV makes a loud knocking when all 3 of the following occur simultaneously, overdrive kicks in, engine fan system turns on and accelerator is pushed. Does anyone have an idea of what could be caus...
Without more info, I'd add check the fan clutch and the water pump shaft for loose bearings. It would be helpful to break out whether this is engine spark knock...
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 07, 2026
