Desert_Captain's avatar
Desert_Captain
Explorer III
Jan 01, 2021
Enlarging my parking for the motorhome...
Since moving to our new home in Payson AZ I've been parking our 24' Class C along the south edge of our concrete driveway {the ability to park the toys on our new .57 acre property being a huge benefit}. Unfortunately with the coach there our access to the attached garage is somewhat restricted. To gain more clearance I had been trying to come up with some more space but there is a fairly steep slope that falls away from the edge of the concrete driveway.
I finally came up with a solution. I dug down 3 to 6" along the south edge of the slab and framed the opening with 8', 6 X 6" beams creating a "box" for lack of a better term that was 24' long and 3'wide. I secured these beams by drilling and driving 2' pieces of 3/8" rebar 18" into the ground and tying the beams together with steel straps and brackets.
I had to remove nearly 2 tons of compacted clay with an assortment of some fairly large rocks that were embedded on the slope. The last step was to backfill my "box" with 1.5 tons of gravel which I compacted by driving over with the Rzr SXS. I still need to do some additional compaction and wet it all down a couple of times but once the passenger side tires are sitting on 2 X 10's the coach should be dead level with the existing slab.
Here is a shot of the finished project:
As you can imagine this was a lot of very physical labor for this 69 year old but I have succeeded in improving my garage access. Here is a shot of the coach in its new parking location. As you can see the the garage has a much easier entrance and though smallish handles my new Can Am Spyder along with my brides car:
:C
  • Looks like you did a great job! Hopefully it will stand the test of time!
    Hard work is good for everyone, any age! Just takes a little longer, but knowing you are still capable, is a great ego booster!
    Jerry
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Dec 20, 2025
