jimmyk's avatar
jimmyk
Equalizer hitch issue - Outside link plate
Greetings--
I've recently purchased a 10,000 lb Equalizer hitch and installed the mounting brackets onto my trailer frame. However, I'm concerned that the outside link plate is the wrong part as it is missing the recess/pockets where the heads of the upper and lower bolts go in so they can be flush with the surface of the plate. Is this a new design for the EQ hitch or did they send me the wrong plate? I don't like the way this has ended up which is causing the L bracket to bend on the top and the two L bracket nuts not being threaded enough to the bolts. See images below:
Pic1
Pic2
Pic3
Looking at the Equalizer parts list, the outside bracket part number is 90-02-5370 and you can see the recess pockets where the bolt head sits:
Mine does not have those pockets.
Has anyone seen this before? I purchased the hitch over a year ago but didn't install it till recently so I think I'm out of any warranty/returns period.
TIA,
Jimmy
  • Ron3rd's avatar
    Ron3rd
    Explorer III
    Hi Jimmy,
    Mine is about 6 years old and has the pocket like shown in your photo. EQ will make it right for you if they boxed the wrong part.
  • I looked at your image and I would not use it like that. Call Equalizer Monday morning. They answer the phone and are very help full. The tech will also give you an email address to forward your picture to.
    Also, while you are at it you may consider changing all the hardware, I upgraded all mine to grade eight bolts, washers and Nylock nuts. All available at McMaster Carr.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
