2012Oudoorsman
Aug 01, 2013Explorer
rightyouareken wrote:
I don't recall what the wear pattern looks like on my L brackets, but I have noticed that the wear pattern on my bars seems to be improving with mileage. They were wearing mostly on one side of the bar when new and are now wearing more evenly across the bar. Think hitch head angle probably affects this to some minor degree as the bars when hooked are slightly off from the axis of tilt, meaning the inside edges of the bars would be very slightly lower than the outside if I'm not mistaken, due to head tilt and the fact that they are at a less than 90 degree angle from the axis of tilt of the head. Also check and make sure your l bracket resting surface is parallel with the bars front to back.
I haven't really been motivated to look into it because it tows ok, but I'm sure you're right that performance may be improved with more even contact between the bars and brackets.
My bars are very close to be parallel. I do have the L brackets angled slightly so the bar rests on them parallel and not at different angles as you mentioned. I do not have many miles and maybe with more use they will wear in as you mentioned. Either way it works good but I feel that an increase in the surface area could make it function great now and during the windy/nasty days.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 17, 2026
