Ron_Gratz
Nov 20, 2013Explorer
Jayco23FB wrote:
TT wt. = 6600 lbs.
Tng wt. = 680 lbs.
I only notice sway when traveling on the freeway (60 mph) and when passed by a semi.
If those are your loaded weights,
your sway might be caused by two small a tongue weight percentage -- 680/6600 = 10.3%.
You might want to change the loading of the TT to see if you can get the tongue weight percentage up to about 13%
That might eliminate your sway problem.
Ron
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
