Turtle_n_Peeps
Nov 20, 2013Explorer
Ron Gratz wrote:Jayco23FB wrote:
TT wt. = 6600 lbs.
Tng wt. = 680 lbs.
I only notice sway when traveling on the freeway (60 mph) and when passed by a semi.
If those are your loaded weights,
your sway might be caused by two small a tongue weight percentage -- 680/6600 = 10.3%.
You might want to change the loading of the TT to see if you can get the tongue weight percentage up to about 13%
That might eliminate your sway problem.
Ron
Winner, winner chicken diner. Ron is on the money. Don't bandaid up your problem. Fix the real problem first.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
