jbres
Nov 20, 2013Explorer
Jayco23FB-
My trailer is nearly exact same weight and length as yours, and I am pulling with a 2500HD also. I have zero sway when being passed by tractor trailers, and only time I can ever say I get sway is on very windy days it seems my entire rig gets pushed around a bit but that may be expected.
BEFORE, buying into a new expensive system, take your set-up to the nearest rv dealer and have them check your setup for proper set up.
OR what I did was I added a second friction type anti sway bar to my set-up. Anything over 25' you are actually supposed to be using two of them not one. I ordered one online (they make them specifically for drivers side of your rig), and installed it and it was a cheap fix for my sway.
Hope this helps
Hope this helps
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
