rfrancis
Dec 07, 2016Explorer
Equalizer hitch
I am looking to purchase a TT and want to get some thoughts on my WD hitch. The TT dry weight is 5600 lbs. It has a 50 gallon water tank so that will be around 450 lbs. I am assuming another 600 to 800 pounds (sound right?) for everything else. That will put it around 6600 to 6800 lbs. The max weight of the TT is 7000 lbs. So the question is if I use 12% for the tongue it puts it at 816 lbs or if I use 15% it is 1020 lbs. The equalizer hitches are either 1000 or 1200 lbs. I don't want more hitch than I need but I also don't want to be under. Any advice would be great?
