CamperWill's avatar
CamperWill
Equalizer Shackles Hitting Frame
Hey everyone, we recently replaced pretty much all of the suspension parts on our tandem axle travel trailer (leaf springs, shackles, equalizers, and bolts) and have run into an issue with the equalizer shackles behind the front axle hitting the frame constantly. This issue did not appear to be present before replacing the equipment. This happens regardless if unhooked, towing level, nose down, or nose up.
We made sure to replace the leaf springs with the same size (26" eye to eye unloaded) per Dexter customer support and per old measurements. We also replaced the equalizer, bolts, and shackles with the Dexter E-Z flex kit(Part #K71-652-00) that was designed to replace the factory Dexter equalizer we had (Original Part #13-104).
Any advice on correcting this?
Drivers Side Back > Front
Passenger Side Front > Back
Original:
  • I think you have 4000lb (26") springs on 3500lb axles that require 25-1/8" springs. The extra ply is a clue.
    The new springs are rated at 3000lb/ea and the axle is rated at 5200lb (Dexter D52). The measurements from center of hanger to center of hanger is 29.5" and the axles measure about 33" apart on center so based on the Dexter sheet below it would be 26" springs.
  • Doesn't matter what Dexters site says. Thensprings are too long! It's very obvious.
  • In the 3rd picture labeled original. Is this unsprung? It looks like your stabilizers/jack is down in the background. In the other two pictures is the trailer jacked up the same way?
    My thinking is you may have the same rate springs as far as load goes but, since there is an extra leaf, maybe the longer spring flattens out more before (i.e. it is a lower rating by itself than the original long spring) transferring weight to the other springs. This results in a longer/flatter spring when holding the static weight.
    The third picture is unsprung, jacks were down and that side of the trailer was lifted off the ground. The other two pictures are with load on the springs, when completely unloaded (e.g. lifted off the ground) the equalizers sit correctly.
    If the springs are too long am I correct in assuming the options are:
    1) Replace all 4 springs, u-bolts, and bushings again with what I assume should be 25 1/8" springs
    2) Find a shop to move the hangers a bit
    We had two issues that we tried to resolve, the first issue is one of the rear leaf springs were worn out so we decided to replace all of them with slightly higher capacity ones (We fulltime and tow at max capacity often). The second issue is our ass-end kept scrapping on slight angles when towing leveled so we got lift blocks + thicker spring packs to give it the extra clearance.
    Here is a picture post-install that has some weight applied to the suspension.
  • At this point I see two options for you.
    1. Contact Dexter. Get them these pictures and see what they say.
    2. Find a trailer repair shop, not an RV shop, to give you suggestions. If you decide to move the hanger locations you want to make sure it is a shop that knows what they are doing.
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 18, 2025
