Gold's avatar
Gold
Escalade/Denali or Suburban 2500
I’m considering buying a 2010 Escalade/Yukon XL Denali or a similar year Suburban 2500.
I currently have a great running 2003 Suburban 1500 5.3L 285hp autoride which I’ve upgraded with stiffer z51 springs and has fresh GM autoride shocks. I recently obtained a 20 foot v-nose toy hauler, I’m guessing the weight of the loaded trailer (and people/cargo in the suburban) is 6,000 lbs. Fortunately it’s very level and stable when towing because I can’t have a WDH as the v-nose on the trailer prevents a WDH from being used.
My issue is that I simply run out of power with the Suburban. I can’t use cruise control on the highway as just the slightest incline (or even the wake of a truck) will cause the Suburban to gear hunt, and even when not using cruise control it’s hard to maintain 60 mph.
I’m considering either a 2010 Escalade ESV/Yukon Denali XL (both have 6.2L 402HP 1500 chassis), or a similar year Suburban 2500 which has the 6L 355HP 2500 chassis.
I’m more attracted to the Escalade/Denali as they are quite a bit less expensive and exponentially easier to find (and have a bigger engine and 47 more HP), but can it tow ‘as fast’ as the Escalade/Denali despite it having 47 less HP that I should consider it. Thank you in advance for your insight.
  • Good responses thus far.
    You already know the Esc/Denali will handle the trailer just fine. And you are ahead of most inthat you can slap a heavier rear suspension in it if you desire. (And that’s a cheap bang for the buck towing upgrade)
    I’d lean towards that for power and value.
    BUT if you’re thinking long term, chances of getting a new HD suv, ever, in the future, are slim. So if you can get a good low mileage one now and take care of it, you’ll have the better vehicle in the long run and have your cake and eat it too for however long that one lasts.
    Btw, if you pick up the 2500 and it’s not enough juice, a Westers or black bear tune and set of headers will net you a little more than the Denali engine. Just headers is good for 20+Hp and around 60 with a real tune and premium gas. Not huge but noticeable.
  • Is this replacement vehicle a daily drive or just a tow vehicle? If just a tow vehicle I would go with the 2500 Suburban. I have no factual evidence that the 2010 Suburban 2500 has a 4:10 rear end. But my two 2500 Suburbans both have/had a 4.10 rear end so I'll bet it does.
    If a daily driver and a decent rear end (3:73 or 4:10) go with the Escalade. It's not a great tow vehicle, but it will do fine with a 6,000 lb trailer. And it will be a nice vehicle to drive around when not towing.
    I'm curious though why a V nose trailer would prevent you from having a weight distribution hitch? Is it a contact during turns concern? Almost all of the hitches hang under the tongue so they should not contact anything.
    One more thing, don't be put off or reject a Suburban with just a torn up drivers seat. You can buy new seat cover and foam as needed and install for about $500. I'm not talking about just an add on seat cover but an actual replaced seat that will look like new. I know in my search for a replacement Suburban I passed up many seemingly good Suburbans based solely on the torn up seats. Only after I finally found my current Suburban (with an already replaced bottom seat cover) that I learned that it was even possible.
  • Whatever you do make sure it has the best rear end gear ratio you can get. Most of those trucks have 3:23 gears which suck for towing. I would find something with at least 3:73 gears to make things tow better. The rear end ratio will kill you if not. Had a Tahoe years ago that had a 3:23 and I burned up the rear end as well as had very poor towing performance.
    Curly
  • Finding a 3/4 ton burb in good condition of that age group will be a challenge IMO.
