  • cm wrote:
    What about having a escape type rope ladder stored next to the window?
    That is a good idea cm, I see they are not too expensive or bulky:
    I like this one.
    This one is a little weird because they say you can only use it once. That would mean no practicing?
    Another thing to think about is that in some cases the RV door may be the closest exit, but a lot of us latch the bolt lock at night. Some fire situations limit your vision. It is a good idea to practice finding the bolt latch lever, knowing which way to turn it, and opening the door latch all with your eyes closed.
  • AS I have always preached on this forum,and to my family "Safety First" that is a must. stuff happens to all of us and if it hasn't happened to you yet, it will. You never know when it will happen so at least talk about it, if you don't practice the escape.
  • I have a Fleetwood 'C'. The escape hatch is the rear window over the bed, but it is NOT hinged. You open the handles and the window falls out, probably for a faster exit. I've heard that they're impossible re-seal. OTOH, if you needed to use the hatch, I don't imagine that there would be a frame left to hold it.
    If you have a setup like this, fight the urge to see if it works.
  • It is interesting that there is no mention of the added safety of having a driver's door. A DP like that shown in the video probably only has a door at the front passenger side. Or even a mid coach door.
    The comments after the video mention why didn't he demonstrate someone his size using the escape window? Plus he keeps calling it an escape hatch?
  • Ivylog's avatar
    Ivylog
    Explorer III
    Thanks for posting this as I went out and tried mine. It was a lot harder to open than one would expect when it has not been used. The rubber seal was stuck and it took several times of pushing hard on it to open. I sprayed the rubber seal with silcone spray and now it's no problem to open. Thanks again.
  • The thought of being in that scenario is frightening.
    Blanket is a good tip and I'll try to keep that in mind should the scenario EVER present itself.
    For my thoughts on what I saw.. Not sure what the spray is? Jayne was asked what they used to lube the hatch and she just bascially said.. This stuff here in my hand (holding generic spray bottle).
    I think if faced with the scenario that required myself or loved ones to leave VIA the emergency escape hatch I'd likely not be taking the time to find a "macadoodle" to hold the window open. My body is likely going to do that as I propell myself through it. I'm sure this would be appreciated by those who are waiting to go out next and any harm or injury as a result will be minor considering the circumstances. I was worried poor jane was going to knock that stick out of the window.
    Why don't RV manufacturers put a gas strut on those windows to hold them open? Seems the current standard can be improved upon.
    My concern was always my daughter.. My fridge is located central the RV were say it could catch fire.. If I go out one window.. Can't get in the door then how do I gain access to the rear to free my child? I bet she has no clue on how to escape.. I need to show her.. Thank you for bringing that to my attention.. You could have saved a life today!
    If nothing else this video has made me realize that getting out or escape routes out and in of the RV should be a major consideration when purchasing an RV. It will be on the top of my list.. NEVER did I consider it before as I'm sure most others as well.
  • Thank you for this! I had never thought about how to get the window open, how to prop it or getting out ------------ we'll be practicing this today! And I feel for those that have lost their rigs to fire, too.
  • I know a couple that had their carburetor catch fire, and the whole motorhome burned to the ground in a few minutes, the propane tank being especially loud!
    Now she sits with her purse in hand, by the front door passenger seat in the replacement motorhome, ready to jump out and detach the towed car. Lucky for them, it has not happened again.
    When they showed up at the hotel the first night after the RV caught fire, they had been sifting through the ashes of the RV, looking for their jewelry, or anything that was left, such as keys, it had all melted. So they looked like a couple of bums.
    They had no clothes, one credit card, and not much cash. At least everything was replaceable! And they still had the Bronco II they towed behind their motorhome to drive home in.
    For anyone that this happens to them, I do feel sorry for you!
    Fred.
Looking for advice before your next adventure? Look no further.25,122 PostsLatest Activity: Apr 08, 2025
