dcason
Jul 12, 2014Explorer II
Eternabond...which product(s)
Going to use eternabond to reseal some roof seams (jayco class c)...roof wraps over the side and butts up to a metal trim piece that is screwed in with a piece of vinyl. Going to clean well, and use eternabond. Rebed some exterior lights also.
Questions:
What eternabond product to use? 2" wide Eternabond Roofseal? Should I also get some double sided eternabond to have and use in other applications? (rebed those lights)
It seems that the passenger side rear has a swatch of delaminating
fiberglass. It also appears that we have had a MUSHROOM growing out the very bottom of the rear...SOOOOOOOOOOO there is water getting in somewhere. NO interior indication or in any compartments and neither one of us can decide whether this was there when we bought it or not.
Hubby took off part of the metal trim strip and the screws did not appear to be sealed in any way (thanks a bunch for that Jayco!)...so he is going to seal them...probably with eternabond double sided)and
check for any rusted ones.
Should we take off the metal strip to see what is behind the fiberglass and see what is actually going on? Should he Take off metal strip and put double sided eternabond behind it? Hubby is very much a Mr. Fix it so he can handle just about anything...just hasn't done much on rv's.
Also going to try a pressure test...next week when we return from a short outing.
Questions:
