mlts22's avatar
mlts22
Explorer II
Nov 15, 2013
Evaporation and black tanks...
In April, I "summerized" my TT (poured 5-10 gallons of water in black and grey tanks after a crushed ice treatment, then completely rinsing and flushing the insides out.)
Last weekend, during the winterizing process, I hooked up my macerator pump to empty both tanks in preparation to add antifreeze. The grey tank was bone dry, the black tank had about a liter of water in it at most. Thankfully they were well cleaned out, so the "son of a poop pyramid" was not an issue.
Just a warning to people... if one forgets to empty a black tank, it might just "empty" itself in a very unexpected way, if one isn't prepared for it.
  • Go to WalMart and buy a $20 clear flush king with a valve. Put it on the end of the line with the valve shut and see what you got in 48 hours. I'm guessing you got a leaking valves.
    If that isn't the case, you now have a flush king to use in the future to clean the tanks with.
  • fla-gypsy wrote:
    Dog Folks wrote:
    fla-gypsy wrote:
    How can water evaporate from a sealed container with a closed valve? I find that highly unlikely. Do you have any other theory other than evaporation?
    It is not sealed. It has a vent pipe through the roof.
    I understand the vents but I got to tell you I still think that is highly unlikely considering the amount of water they said they added. I have never experienced anything like that sort of evaporation.
    In theory, I agree with you. IF the amount of water the OP says was put in, and there are no slow leaks, I cannot think of any other way.
    But then again, I'm not that smart. LOL
  • You also need to keep the seal moistened (some water/antifreeze in the bowl to keep seal operating nicely and not leaking fumes).
    Donna
  • April you 'summerized'and Nov you 'winterized'.....water you left in tanks evaporated between April & Nov?
    You need to use that RV more frequently :B
    If leaving RV unused for extended periods.......pour some RV anti-freeze into tanks. Even in summer time. The RV anti-freeze will not evaporate as quickly and the tank bottoms and dump valve seals will stay wet.
    Even after a through cleaning there is still some stuff left behind due to the tank design and lip in side of tank below the drain line.
    Best to not let them dry out.
  • Both my black and grey tanks have decent roof vents. If not, the smell would wind up in the rig.
  • How can water evaporate from a sealed container with a closed valve? I find that highly unlikely. Do you have any other theory other than evaporation?
Looking for advice before your next adventure? Look no further.25,187 PostsLatest Activity: Mar 18, 2026
