navegator
Jul 04, 2015Explorer
You need to calibrate that sensitivity, otherwise you are going to end with warped rotors and burnt brake pads on the toad, those brakes should only come on when applying more brake pressure on the RV, I do not know if you can set the sensitivity from the drivers position.
navegator
navegator
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 22, 2025
