murraymcleod
Mar 02, 2015Explorer
From the link you supplied:
Do I need a Brake-Lite Relay?
You only need a Brake-Lite Relay if you’re installing a supplemental towed
vehicle braking system that pushes or pulls the brake pedal.
Exceptions –
• With the engine off step on your brakes. If the brake lights do not illuminate,
you do not need a Brake-Lite Relay.
• If you’re using magnetic tow lights or a bulb and socket wiring kit, you do not
• If your motorhome is wired for separate brake and turn signals and if your
towed vehicle is wired for separate brake and turn signals, you do not need a
Brake-Lite Relay.
It looks like I'm exempt from the relay based on the second bullet. So if I don't need the relay wired in, does the transmitter need to be hard-wired into the toad for any other reason?
Exceptions –
Brake-Lite Relay.
Looking for advice before your next adventure? Look no further.25,210 PostsLatest Activity: Aug 29, 2026
