murraymcleod
Mar 02, 2015Explorer
enblethen wrote:
According to the installation instructions, only hard wired item would be the brake away switch. It needs to be plugged into the brake unit.
It does not connect to any of the toad wiring, It is a separate wiring harness.
Yes, I would plan to permanently mount the break-away switch near the front of the toad, and then route the wire through the firewall, and then connect/disconnect that wire as needed from the transmitter unit.
It seems strange that they recommend the hardwiring of the 12v power for the transmitter (rather than an un-pluggable 12v connection), as then the transmitter would always be "on" whenever driving the car. Doesn't seem like that would be good for the unit over time....
Looking for advice before your next adventure? Look no further.25,210 PostsLatest Activity: Aug 29, 2026
