murraymcleod
Mar 02, 2015Explorer
UsualSuspect wrote:
You do however need to connect a wire from the cold side of the brake light switch to the towed's ICX (The transmitter box with the antenna). This wire sends a signal to the ICX telling the unit the brakes are applied, and will send a signal to the remote in the RV that will trigger a red light, and change the display from "Ready" to "Braking". The EvenBrake also has a feature if the brakes are applied for to long it will automatically release them, as well as alert you if it does not, this wire needs to be connected for that to happen...
So, if I read right, the transmitter (ICX) needs to use the voltage from the brake light switch on the toad to know when the Evenbrake is applying the brakes? It doesn't get that info from the braking unit itself (?).
Seems a but strange for the system to rely on another switch for that info, but if so, then I guess I may as well hard wire the ICX in (and have it power on whenever I drive the car, which will happen a lot more frequently than when I'm towing, as this is a car I use daily when not RV'ing!). Thanks to all for the good info!
Looking for advice before your next adventure? Look no further.25,210 PostsLatest Activity: Aug 29, 2026
