murraymcleod
Mar 12, 2015Explorer
OK..got the Even Brake all hooked up (hard wired everything) and found that the 12volt receptacle in the center console is rated for 20amps, so all is good, and the Even Brake tests out OK!
Went for my first test tow this evening, and all seems fine.....except the Even Brake compressor runs about every two minutes, even when just sitting there in standby mode and doing no braking! Is this normal, or do I have an air leak somewhere? I'm afraid the constant compressing will run down the battery pretty quick!
Looking for advice before your next adventure? Look no further.25,210 PostsLatest Activity: Aug 29, 2026
