Swmpbgy1
Jul 01, 2015Explorer
Mr_MrsSchlepprock250 wrote:
Bottom line is... You need a 6.0 transmission cooler. They bolt right up to the stock location, you just need some rubber line and a few fittings. The stock transmission cooler for the 7.3 equipped trucks is way too small.
I will ECHO this....I have the same truck as you.....same problem. Replaced the stock tranny cooler with the MUCH larger 6.0 cooler and all my transmission problems went away......remember, heat will kill the tranny in our excursions......Best of luck.
Swmpbgy1
Looking for advice before your next adventure? Look no further.25,184 PostsLatest Activity: Sep 04, 2018
