fugawi's avatar
fugawi
Explorer II
Nov 08, 2014
Expedition Tongue Weight and Bow Wave Push Questions
Hello –
Could you please help me understand the variables better?
Tow Vehicle = 2015 Ford Expedition 4x4 with:
1. 7,500 LB GVWR,
2. 3,550 LB Front GAWR,
3. 4,300 LB Rear GAWR, and
4. Max occupants + cargo of 1,347 LB.
According to manual, max tongue weight = 600 LB weight-carrying and 920 LB weight-distributing. Max trailer weight = 6,000 LB weight-carrying and 9,200 LB weight-distributing.
I am towing a Funfinder 189FDS.
According to CAT Scale,
1. Expedition by itself was 6,060 LB,
2. Expedition front axle when hitched to trailer was 2,640 LB
3. Expedition rear axle when hitched to trailer was 4,200 LB
4. Trailer by itself was 4,260 LB (loaded for camping with fresh water full),
5. Tongue weight was 780 LB. I did not have any weight-distribution at that time.
I got the Expedition thinking that I should be able to tow a 4,500± LB trailer with no problem and that I wouldn’t need to mess with weight-distribution.
I’m a little surprised to have a 780 LB tongue weight on a 4,500 LB trailer, but that is what it measured.
My initial questions are:
1. Based on the facts above, must I use weight-distribution?
2. Is it possible to reduce the tongue weight by loading the back of the trailer with more weight? I am planning to put on a trailer receiver that may carry 300-400 LB of cargo. Is it likely I can get the tongue weight down to 600 LB?
3. What determines the 600 LB tongue weight in the manual? Is this the strength of the metal that comprises the hitch? Is it to help to not exceed the 4,300 LB Rear GAWR?
In addition to the questions above, I noticed more bow push than I expected when driving on the freeway. The biggest impact was when I was loaded with fresh water and there were 15-20 mph winds. I was traveling at 65 mph and when a semi or bus would go by, there would be a pretty good push and sway. I noticed it more when they would pass going maybe 10-15 mph faster than I was.
On my return trip, the winds were lower and the fresh water was empty and my tongue weight was about 50 LB lighter than the initial 780 LB. I didn't experience as much bow wave push.
1. Would any part of my setup contribute to the bow wave push?
2. Would weight distribution reduce it?
Thank you.
  • Having towed with an Expedition in the past, with exactly the same trailer weights you are posting....Yes, you need weight distribution AND sway control.
    Keep in mind that the Expy has a short wheel base and "P" rated tires. Both are not optimal for stability.
  • Your posted weights alone tell you that you need weight distribution. Your experience has told you the same, plus it has told you that you need sway control. If you put more weight to the rear, your sway problem is only going to get worse.
    Bruce
Looking for advice before your next adventure? Look no further.25,115 PostsLatest Activity: Feb 27, 2025
