salem's avatar
salem
Extension Cord Question
I've learned on these forums that you don't want to use too small an extension cord to plug into something that requires a heavy load, such as electric heater, your RV, etc. My question is can you use a heavy duty cord on items that do not require one? Specifically, we're putting up Christmas lights and I'm wondering if I can use the heavy duty cord I use to plug the RV into the house (via the adapter) to run low voltage lights? Will it cause damage? Thanks.
  • Within reason using a larger pipe than necessary isn’t ever a problem.
  • Thanks, fellas. I've been meaning to ask that for a long time. Appreciate your speedy responses.
  • Shouldn't be a problem at all....
    Any appliance can use a shorter or thicker, lower-gauge cord.
  • as long as it is plugged into the correct voltage no harm. It's overkill but if it keeps you from needing to buy another cord, not an issue.
Looking for advice before your next adventure? Look no further.25,147 PostsLatest Activity: Jul 04, 2025
