Boomerweps's avatar
Boomerweps
Eye opening CAT weighing
For last weekend's camping, I was going by a truck stop with CAT scales and wanted to get some ready to camp weights on my rig. Onboard was my wife, lab, & me.
I had to get out to use the call buttons, likely causing a little of the noticed errors, like the reweighing being 160# less, even though I tried to at least straddle the 1st & 2nd scale platforms. For the reweigh, I just took off the load bars and put them in the TV.
My TV GVWR IS 6180, with WDH the TV axles totaled 5920, without WDH 5840.
Front axle rated at 2960, with WDH 2600, without 2380.
Rear axle rated at 3340, with WDH 3320, without 3460!
Trailer axle weighed in with WDH 3680, without WDH 3600.
First Gross weight was 9600, reweigh was 9440?
So yes, the numbers do NOT all match up mathematically.
I did not unhook for a tongue weight nor did I get a just the TV weight. Two missing parts of the puzzle. The TV is rated to tow 5225 with the factory tow package, so I have got a good safety margin there, although I only have 260# margin on my GVWR when using the WDH.
What I do surmise, I am slightly over weight on my rear axle until I put the load bars on. I need to put anything I can from the TV into the trailer and clear out whatever gear I can out of the TV. The WDH is putting 220# to the front axle.
Other than get a new TV (not an option this year), any comments or suggestions? Should I increase the leverage on the load bars to move more weight to the front? It's a flat bar and platform linkage, so not as simple as bumping up a chain link. Husky Centerline with 600/6K load bars. Right now I feel really stable and level when towing.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 17, 2026
