Hi Guys,
Let me add some technical findings to the issue. I have been around machine building all my of my career and I'm now retired. You can build a shaft and seal to run true and hold back lots of psi of oil or grease pressure. They do it all the time on hydraulics. We are talking 1,000's of psi here.
But we are not talking heavy duty industrial in this case. The seal leaking we are talking about in on an RV...
Let's look at some of how the problem on leaking grease comes about.
See this pic of out of our camper. It was bought used like that and we drove to PA to get it. Yes, a state that inspects trailers. At that time it had Alko axles and no EZ lube axles. When I brought it home, I went through the brakes when I changed the axles that were out of tolerance to know what I had. Sure enough, here is one drum
This is non EZ lube and a standard hand pack by whoever did it and by who ever did the 2 years of PA inspections. This is the first time I had the wheel off.
How did the grease come out? It was not the EZ lube as it did not have it. Well, they could have nicked the seal during an inspection, it could of been cheap grease with a low temp rating, there is heat involved from long distance towing that creates grease expansion pressure and there is centrifugal force of the grease flying around and it could of been the mechanical setup. It could be any of them or a combo. On a standard hand pack that was not that heavily packed, the grease had enough pressure/flow to works itself out of the seal that may have been compromised or had parts issues.
Hold that thought, let's look how a trailer axle spindle and brake setup is made.
If you have ever changed rear axle seals on a 3/4 or 1 ton truck and you go to the parts place, be ready to drop a $50 to $100 for 1 of those special rear axle seals. The rear axle casing is vented so it is not pressure seal, so why such a good expensive seal? Well, they do not want it to leak. When you go to get a trailer seal, the cost can be from $3 for a cheapo one to $7 for a Dexter double lip that works with their EZ lube
https://www.easternmarine.com/dexter-2125-id-grease-seal-010-010-00Why 10 to 50 times more cost for the truck rear axle seal then the trailer axle seal?
Next, is the manufacture of the housing the seal is mounted in. If you ever look up the design spec's of the type of seals used in trailers, the seal and shaft are supposed to run true to each other within a small tolerance. See here when they talk about "runout"
http://www.skf.com/us/products/seals/industrial-seals/power-transmission-seals/radial-shaft-seals/coaxiality-and-runout/runout/index.htmlRunout in this case means the seal needs to be running true to the shaft within about 0.004" to 0.005" TIR (total indicator reading) or else the lubricant can work it's way out the eccentric clearance between the seal and the shaft. I came up with that tolerance off the SKF chart since a trailer wheel of 27" (ST205/75R15) dia spins at around 685 rpm doing 55 mph. Larger tires spin a little slower, smaller tires a little faster. And a CRW5 and CRWA5 seal is close to what is used on our campers.
SKF CRW5 The runout chart
SKF Runout chartGranted there is a garter spering to help keep the seal lip against the shaft. But in time, the seal lip will wear more/deteriorate more the larger the runout is and inertia is always at work.
So how good do trailer wheels spin? Well in my experience not very good.
See my post from when I converted my manual adjust brakes to Dexter Never-Adjust
Dexter Self Adjusting Brakes (long W/pics and details)I had one Alko original brake drum with 0.028" TIR runout. I called Dexter after I bought 4 new drums and their spec is 0.015" TIR. And 1 of the 4 drums was outside that.
Basically the seal bore runs true with the brake lining surface. But the seal does not run true with the bearing bore. This is a machining setup issue but it doesn't matter as the spec is so wide open a lot of this is in spec.
I asked Dexter, why can't these drums run more true like automotive does? Getting a seal bore to run true in automotive in less than 0.005" TIR is done all the time and 0.0005" TIR on disk brake rotors too. He said no one rides in a trailer and the vibration is acceptable where in a car it is not. He did not tell me it was to save cost, but in the machine shop world precision costs more $$$.
Have you ever adjusted the manual brakes on your camper? Spin the wheel and you hear, skip, skip, skip of the drum only touching for a portion of the drum revolution. Why? The drums runout out that bad.
Point: Yes, a "good" seal, on a "good" surface shaft, with a brake drum that spins "true", has "good" high temp grease has a chance of lube not coming out.
The reality is this is an RV.... the seal is cheap, the brake drums do not spin true, shaft finish has issues, the grease type is unknown in some cases. Then with EZ lube we pack that seal side solid with grease right up to the seal edge trying to force grease through the bearings. And when that packed grease warms up from towing long hours, it can thin, expand and works its way out towards the brakes due to the runout issues and or a poor seal quality setup.
I'm not trying to convince those that have had good luck with EZ lube to change their ways. Yours might be in the better machined side of the tolerances. Just pointing out how the trailer setup we have can fail. Do you really think these RV's are built to tight tolerances?
Hope this helps
John
