willald
Jul 17, 2013Explorer II
truenorth50 wrote:
I took and applied all the good advice posted here and went one step further. I had two 20" pieces of two inch angle iron welded ( with the point up) to the dolly, to form a physical obstruction to prevent the tires from rolling. Coupled with the straps and chains, I have managed to eliminate the tire movement altogether. The angle iron forms an 'indentation' that the tire sits in and 'voilà!' the problem is gone.
Hey, not a bad idea, I like it. When you get back home, any chance you might post some pictures on here of what you did?
Will
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
