Repeat below the images showing how MC PSI is developed over time, over brake pedal stroke
Unless trailer brake controller also an inertia (accelerometer), the trailer brakes will NOT be turned on as soon as my P3 will
Because my P3 is turned on with the brake pedal light switch and is before the MC ever develops any PSI
Meaning my trailer brakes will have power sent to it before any MC PSI based controller will. Makes no matter highly integrated or after market
Add that there are both min PSI before it will trip and hysteresis in most of the PSI sensors I've ever reviewed and used in my brake designs. Wonder what these Highly Integrated trailer brake systems have as their min PSI trip and what their hysteresis is (hysteresis is the incline of ramp both in turning on and turning off)
For those who do not know HOW2 read these two graphs...the vertical axis is the amount of PSI being developed by the MC and the horizontal axis is the brake pedal to MC piston stroke (one in distance...other in time)
Sensing brake pedal light switch will have it switch on BEFORE it ever touches the MC piston on my setup and is the way GM has designed its brake light switch.
This is how my P3 leads the trailer brakes BEFORE any MC PSI sensed system. Even the newest one which sense vehicle network information...unless that too has an accelerometer and also senses brake pedal light switch
Bottom line is you, the individual decide which is best for you, or that you like best. I'm just defending with actual information for those on the fence looking for information for their decision
BenK wrote:
snip...
Here are a couple curves showing graphically what am talking about
Rod stroke vs wheel brake PSI...this curve shows the brake pedal to MC rod travel distance vs PSI developed
Brake system PSI over time or vs TV brake pedal stroke
Pascal's Law (hydraulic pressure ratio) showing why the MC piston stroke must be much longer before the brake caliper/cylinder even moves enough to press the friction material hard enough onto the cast iron to create braking friction
