travelnman's avatar
travelnman
Factory Installed Brake Controllers
Anyone experienced factory installed brake controllers? I heard
they are weak and don't provide enough juice to strongly activate
the trailer brakes but others say they do work OK. Trailer Life
says you need to follow the factory instructions in setting them up,
true but why then are the folks I talk to saying they still are
not working right. I have a after market and it can squeal the TT
tires if I set it that way but factory units are not able to do
that. I would prefer as much juice to those brakes as you can get when
in a emergency. I like the way they look on the dash built in but
again there is another difference, they seem to be all mounted on
the left side and I'm right handed not sure how I would like that.
Any comments would be appreciated I'm about to buy a suburban with
a factory brake control mounted on the left. Dennis B.
  • I have the factory controller in my 16 Ram and love it once I learned to set it up. Factory settings you could turn it all the way up and barely feel the trailer brakes working. Once it was set right I have my gain on around 4.5 and the trailer will stop the truck from rolling just by manually pressing the control like it's supposed to.
    Mine is also on the right hand side in the dash.
  • donn0128 wrote:
    Because of the vast number of adjustments possible, most problems seem to be lack of understanding and or lack of correct setup.
    I'll agree with donn, these don't operate the way the after market ones do. If you're expecting the "tug" from the trailer brakes, you won't get it. The IBC is much smoother and works in concert with the truck brakes. I've never had a problem stopping with them or felt the trailer brakes weren't doing what they should.
  • Because of the vast number of adjustments possible, most problems seem to be lack of understanding and or lack of correct setup.
  • mine works fine as well on an F250 on the the right hand side.
  • Mine is great and have had no problems with it. 2015 Ram 2500
  • I love my factory installed controller. It's connected into the truck's computer system, so it knows exactly what the truck is doing and how much brakeing is being applied and controls the trailer equally.
Looking for advice before your next adventure? Look no further.25,174 PostsLatest Activity: Nov 02, 2025
