speediq99's avatar
speediq99
Explorer II
Jun 01, 2021
Falcon shocks for towing. Any good?
Hello,
I am thinking of adding the Falcon adjustable Tow Shocks to my 2021 F150 Powerboost crewcab.
I tow a 7400lbs trailer. The problems I am trying to solve are slow bounce recovery when driving on roads with small bumps and a little bit of front end floating when driving in 20mph winds. I use an equimizer and it is set properly to distribute weight front and back. The truck just bounces and floats a little in windy and road imperfections.
Would the Falcon shocks help?
Would adjustable airbags do better?
They are priced about the same. I just need to make a choice if they both make any difference at all.
???????MC
  • Shocks won't fix frontend floating. You need to shift more weight.
  • I'll say not enough to cover the cost of the shocks. Plus you would need to enquire how they are valved. In my experience, most off the shelf high $ remote res/rebuildable shocks are designed for quick compliant valving on small bumps and big resistance on ground out type bumps. Aka high speed off road driving.
    That said, a properly valved set of big shocks could help.
    I just don't see needing to put new shocks on a brand new top of the line pickup to tow a modest load.
Looking for advice before your next adventure? Look no further.25,171 PostsLatest Activity: Oct 21, 2025
