calewjohnson's avatar
calewjohnson
FantasticFan Power
I am looking to add a FantasticFan to the vent in the kitchen, our stove vent doesn't vent outside, and the ceiling vent is right over the stove. I have a question about a power supply for the fan...I pulled the shroud off the existing vent and found the wires that go to the 12v ceiling light near the vent, would this be a good source for power or will I need to look somewhere else? The only downside I would see with using that wire is that those lights are switched. I would really like to not have to run wires back to the power panel. Any help would be great!
Cale
  • Yes, test the circuit like wbwood suggested. You can use a needle to pierce the wires so you won't have to cut them then splice them back just to test. I did the same installation for the same reason. In my 5th wheel there were three wires - a ground, a switched lead and one that was hot all the time near the old unpowered vent. Don't know why it was there, but I didn't question it - just used it to power the Fantastic Fan. Negative will probably be white, hot will be black or brown. The Fan doesn't pull much power.
    No more smoke alarms while cooking breakfast...
  • What gauge is the wire (probably 14 stranded) and what else is on the circuit? Check the fuse what amp rating?
  • Test the wires with the light off at the switch. We had two fantastic fans installed on our class c. Because not knowing anything about the electrical and whether or not there would be wires at our existing vents, we opted to let CW install them. Didn't cost a whole lot to have it done right and no worries.
Looking for advice before your next adventure? Look no further.25,151 PostsLatest Activity: Jul 27, 2025
