bobinraymoremo
11 years agoExplorer
YC 1 wrote:
You need to find a couple of places you can conveniently test when it acts up. You can use a push pin to penetrate the wiring. Test before the fault occurs so you have known references. Write them down, do not try to remember them. The more locations the better. Intermittents drive technicians crazy and we can only work on symptoms and common failure places. Catching it broken makes it much easier.
So far has happened in the middle of nowhere Montana or Wyoming. Intermittents also drive the drivers crazy :-)
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: 5 days ago
