- aruba5erExplorerThey have been making the same ineffecient furnace for years because propane was only .25 cents a gal. What incentive does the camper maker have to put in a better one. You can BUY a 2 stage furnace from Atwood but the trailer maker ain"t gonna pop for the extra money. Would also be nice to make them a little QUIETER
- mr__edExplorerYep, it's normal. May seem inefficient but it's the only way to use propane safely to heat the RV (I wonder if that contributes to global warming? :B). For that reason I generally use electric space heaters if temps don't get too low. The main reason I use my fiver's heater is to keep water pipes from freezing at night. Even then I keep it at the lowest setting possible. In my previous RV I would place an electric lamp in the area near the fresh water tank and associated plumbing to ward off freezing at night.
- harold1946Explorer
301TBS wrote:
The exhaust will melt your lawn chairs too!
Yes, and if that much heat were hitting the plastic registers inside they would melt also. - dakonthemountaiExplorerIf I am correct, because that heat is the exhaust vent from burning propane it's not all that good for you if you are too close and breathing the fumes... Unless, of course you are into that! ;)
Dak - 301TBSExplorerThe exhaust will melt your lawn chairs too!
- goodwin297ExplorerThank you for your replies. Some pretty funny. :)
Trudi - nomad297ExplorerWow. Admin really took care of that idiotic post in a hurry. Good job.
Bruce - SteveAEExplorerWell there you go. Stick it outside your furnace vent and you can get a whopping 3.5 watts :R
- pianotunaNomad IIIHi SteveAE,
Funny you should mention that. My brother bought me a TEG (cup) as a birthday gift. It is only intended for doing cell phone recharges. - SteveAEExplorerThought of differently, a 20% loss (6kBTU) on my 30kBTU furnace is equivalent to ~1.8kWhrs. (Ugh, how I hate that furnace.) So yes, it will feel hot.
Pianotuna: I did some experiments using TEG's (Thermal Electric Generators) to recover some of the lost heat in the furnace exhaust by converting it to electrical current to charge the battery. However, the efficiency (<~15%) of those devices just makes it too impractical.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 16, 2026
