johnhicks
May 11, 2021Explorer II
Only the manual-transmission Fiat is flat-towable.
The key isn't needed for the steering.
The lighter/accessory outlet is switched by ACC. You could jumper the breaker to make it always live, run a new wire to an outlet or use an accessory battery pack. The Fiat forum folks appear to believe the jumpering the breaker won't blow up anything but no one's actually done it. I'll do that when I get around to installing the brake. I'm legal without braking but I intend to go with a RVI Brake. I have a Roadmaster air brake rig I used on the Tracker but it won' t work with the Fiat, and it's kind of an overall kludge anyway.
Looking for advice before your next adventure? Look no further.25,207 PostsLatest Activity: Aug 27, 2026
