rvexodus's avatar
rvexodus
Fifth Wheel - Tire Drag
Need some help here. We pulled into a state park yesterday and as we headed to our spot a tire blew. Turns out the tire was dragging (not spinning) until it blew the tire.This is a triple axel @ around 20k lbs. We didn’t notice any real drag or hear anything until the tire blew. Looks like it started dragging at the park enterence. After we realized it blew and wasn’t spinning we babied it into our spot leaving a very long skid mark along the way. As we pulled into our pull through spot, we backed up slightly which allowed for some reason the tire to spin again.
I’ll pull the tire and inspect the breaks and bearings in the next day or two. However, I’m not a wheel, break, bearing, axel expert. What could cause the wheel to suddenly start dragging? I’m worried that everything checks out and looks good with no explanation why it happened. It would be helpful before I rip it apart to get some insights so I know what to look for. Anyone else experience this? Any suggestions what to look for?
Thanks folks!!!
  • DO you know if you have 'self-adjusting' brakes?
    They adjust when going forward and putting brakes on.......might have failed/hung up on that wheel then when you backed up it 'freed up'
    You will know more when you pull drum assembly off.
Looking for advice before your next adventure? Look no further.25,101 PostsLatest Activity: Jan 14, 2025
