The_ugly_duckli's avatar
Oct 03, 2018
Fifth Wheel tire blow outs.
Just an observation.
Traveling south on route 81 from New York to North Carolina with our travel trailer. Within 100 miles I saw two large fifth wheel trailers with left rear tires shredded.?? Do fifth wheel trailers carry their weight evenly on both rear axles? It got me thinking and as I was traveling I started looking at fifth wheel trailers as I was traveling. Many seem tail heavy? Or is it just a optical illusion?
  • N-Trouble wrote:
    Lynnmor wrote:
    There is a tremendous amount of wind pressure against the front of a high profile vehicle. Just look at the fuel mileage drop and know that much of that additional energy is pushing the rear down adding to the effective weight.
    Say what??? I hope nobody reads this and actually thinks there is any logic to this.
    And?????????? Care to expand on your reasons for that comment?
    Barney
  • Road hazard damage is usually the rear tire as the front flips up the object and it damages the tire behind.
  • Axles only get loaded unevenly fore to aft if they are torsion spring axles. Leaf spring axles modulate the angle with wishbone connecting the springs together.
    Within reason of course. One can look and see if there's more room for the Y piece to travel before bottoming out front or back.
    Several inches nose high or low is fine with leafs, not fine with torsion axles.
    ^^This^^
  • N-Trouble wrote:
    ^^This^^
    ^^This^^
    ...and if I was a betting man, I would bet that both trailers hit the same thing, if they were on the same road heading in the same direction.
  • I run a TPMS with temperature and pressure on my 5ver and I've noticed the right side runs 8-10 degrees warmer than the left. This tells me the right side is heavier than the left. Front to back they seem about even.
