Bumpyroad
Sep 10, 2017Explorer
Mickeyfan0805 wrote:
I tried the Next Exit book when we first started camping about 7 years ago and found that most of the listed didn't really show where I could readily fill up while hooked up. Has it gotten any better? Any other suggestions?
Thanks!!
I found that most all of the stations that they had marked in red were reasonably decent to access pumps while I had a toad hooked up. they surely didn't require backing into the pumps. one nice setup I saw was a station that had the pump islands perpendicular to the building and the outer two pumps were marked for RVs. you could pull in along side the island and then exit by going around behind the building. worked great.
bumpy
Looking for advice before your next adventure? Look no further.25,197 PostsLatest Activity: May 23, 2026
