Paleo_Ron
Aug 13, 2015Explorer II
FIRE !!
Well, I just tried to light the propane on the Dometic fridge in my 17' fiberglass trailer and heard a Whummph! and I thought I smelled smoke, so I turned it off. I then tried again, thought I smelle...
Ed_Gee wrote:coolmom42 wrote:wa8yxm wrote:
There is, in fact, a Recall on many models of Dometic (And Norcold) to install stuff to make that less of a happening.. Make sure your new one has that.
I will also add there are two major causes of those fires.
ONE is a leak in the cooling system.. One of the chemicals that makes up the stuff that makes the cold is very flammable.
The other is poor maintenance.
So what should a person do to prevent this?
In addition to frequent maintenance (cleaning), you might consider one of these: CLICK
