Paleo_Ron's avatar
Paleo_Ron
Explorer II
Aug 13, 2015
FIRE !!
Well, I just tried to light the propane on the Dometic fridge in my 17' fiberglass trailer and heard a Whummph! and I thought I smelled smoke, so I turned it off. I then tried again, thought I smelled smoke again, and looked outside to see orange flames coming from the exterior grate! Holy Moly! I got it extinguished, but the plastic grate is a warped mess and the wiring is fried. The trailer luckily was not affected. Also luckily, I have a warranty extension on the fridge.
Has anyone heard of this happening before? I wonder what it would take for a fiberglass tailer would catch on fire?
  • Check to see if your refer is on the recall.
    Have the recall done.
    Clean the refer compartment at least every year.
  • wa8yxm wrote:
    There is, in fact, a Recall on many models of Dometic (And Norcold) to install stuff to make that less of a happening.. Make sure your new one has that.
    I will also add there are two major causes of those fires.
    ONE is a leak in the cooling system.. One of the chemicals that makes up the stuff that makes the cold is very flammable.
    The other is poor maintenance.
    So what should a person do to prevent this?
  • wa8yxm's avatar
    wa8yxm
    Explorer III
  • I would say if you had flames coming out of the grate, you were very close to the whole TT going up in flames.
    I wouldn't want to get any closer.
    Fortunately, you're okay.
    Let us know if you figure out what caused the problem.
Looking for advice before your next adventure? Look no further.25,187 PostsLatest Activity: Mar 18, 2026
