wa8yxm wrote:
Propane tanks are designed NOT to blow for several hours. by then the Professionals will usually have knocked the fire down
Suggestion.. Google "Mac the fire guy" and buy some GOOD extinguishers.. He will tell you what you should have instead of that toy the factory installed.
Not
exactly accurate.. Go outside and look UNDER your tank. There you fill find what appears to be a capped-off access to the tank. Thats an over-pressure valve that releases a LOT of gas and is REALLY loud, and theres no way to shut it off if it fails
