Lusson's avatar
Lusson
First Long Road Trip
Well I'm a first time camper owner and seeing if there is anything I'm missing to be ready for our long trips this summer.
I have a 36' long Travel Trailer finally I believe got my Hitch setup right after taking it to the scale last week. I may do some more checks after the items below.
Installing a second Curt Sway Bar
Getting Load Range E Tires put on my SUV
Got things weighed and got my hitch weight at 950lbs on a 7700lb trailer. With everything loaded in my SUV.
Front and Rear Tires are same spacing as unloaded with Dist. Hitch System.
Only thing curious is the tires and second sway bar will increase travel comfort. On my Dist. hitch I had it on the 3rd link and here is the info I had from the scale.
No Trailer Axle Weights
Front 3340lbs with 36" Spacing
Rear 3480lbs with 36" spacing
Axle Weights On Link 3
Front 3220lbs with 36" spacing
Rear 4540lbs with 33" Spacing
20% Tounge weight
Axle Weights On Link 4
Front 3340lbs with 36" spacing
Rear 4360lbs with 34 3/4" spacing
15% Tounge weight
I'm going to see if I go up to link 5 if that does anything and weight it again but thinking link 4 is the one to go with. But noticed if I got above 65mph on link 3 it got a little light so see how it goes on link 4 and even link 5 for driving comfort.
Looking for advice before your next adventure? Look no further.25,163 PostsLatest Activity: Sep 05, 2025
