kells81
Aug 08, 2013Explorer
downtheroad wrote:
Here are the basics:
++Level the TOW vehicle with w/d bar adjustment...
++Level the TT with the hitch height adjustment...
++Level the w/d bars with the angle adjustment on the hitch head...
Assuming that you are on level ground, it looks like your trailer is nose high which is not good. That could induce sway.
To start with, get an adjustable ball mount shank so that you can lower the ball and the front of the trailer...then go from there with your frame measurements and your wheel well measurements.
something like this.
It has this on it. I leveled the trailer then measured and matched. I think the flaw is the rear is sitting lower than original and should have set the trailer nose low rear high but had just the opposite effect.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 10, 2026
