whiteys29's avatar
whiteys29
Flat Towing a 2000 Tracker with Auto Trans
We are new to towing. The owners manual in a 2000 Auto-trans Chev Tracker we are interested in purchasing as a dinghy says the vehicle can be towed "two wheels lifted or on a trailer". Our understanding was that, with the transfer case in neutral the vehicle can be safely towed "flat four on the ground".
Does anyone have clear, straightforward, knowledge of how a 2000, automatic trans Tracker may be towed?
Thanks
Barry.
  • Suzuki/Tracker 2 WD automatics must be towed with rear wheels off ground.
  • enblethen wrote:
    Very easy to do.
    Put transfer case in neutral
    Transmission in park
    Release hand brake.
    Book says to stop every 200 miles, run engine in gear for five minutes.
    We have had four different Suzuki's, big brother to Tracker. They have all performed good.
    2 wheel drives must be towed on dolly with rear wheels off ground or trailered.
    Actually the Manual Transmission 2 Wheel Drive Trackers Tow Fine! We towed Ours for Ten Years and well over 150,000 Kilometres in Neutral. Key to On to unlock the Steering!
  • I have a 98 Suzuki. Didn't know about leaving the key in off position and wheel would be free. Does it still register miles?
  • You may have been looking in the manual at roadside assistance towing of the car if it breaks down. Be sure you look in the manual for "Recreational Vehicle towing", i.e. towing it behind an RV.
    I had a 1999 4WD Tracker with same experience and instructions as all the others.
  • Thanks to all who have replied with helpful comments. We feel a bit more comfortable about making our purchase of the 2000, Auto trans, Tracker.
    Barry.
  • I have a 2000 Tracker 4WD and it is towable 4down. I never stopped after 200 miles, I never drove any limited speed limit. I retired it but it still goes wherever. You have received the correct transfer case, steering lock, and transmission directions here.
  • 2000 FMCA guide only lists 4WD. Plus 55 MPH and 200 mile limits.
    Regardless your manual seems clear.
  • Very easy to do.
    Release hand brake.
  • Is this a 4WD Tracker? I have had a 2000, a 2002 and now a 2004 Tracker, and have successfully towed all of them. So far a total of about 60,000 miles with no problems.
    Just put the transfer case in neutral and the transmission in park. Stop every 200 miles or so and start it up and put it in gear for a couple minutes to keep things lubricated. I typically do this when stopping for fuel or for a rest stop. I just do a walk-around the rig to check everything while it is running and get back on the road. Take no more than 5 minutes. I never make a special stop because 200 miles went by.
    If you leave the key in the ignition after turning off the engine you can turn it to the lock position and the steering wheel will remain unlocked. The steering column does not lock until you actually remove the key. If you do it correctly you don't have to leave the ignition in accessory position.
    If you'd like and other information regarding my experience with Trackers feel free to send me a private message and I'll give you my phone number.
    • BPenna68's avatar
      BPenna68
      Hi! I have a 1998 Tracker, Auto trans, 4x4 with self locking hubs. Can I flat tow as is or do I need to swap the huns to manual? Thanks! Brian Penna 714-225-8361
      • way2roll's avatar
        way2roll
        Trailblazer
        You may have better luck posting your question in a new topic than a buried response in an 11 year old post.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 07, 2026
