Rhigley's avatar
Rhigley
flat towing a 2018 canyon
I finally got a chance to tow my 2018 canyon and towed with no problem. I placed a disconnect on the neg. side of the battery. Ran a 12 volt outlet from the battery to the cab to run the blu ox braking system, also ran the brake away brake to the cab.
  • 2017 Colorado: From the manaual
    Only dinghy tow four-wheel-drive
    vehicles that have an N (Neutral)
    and a Four-Wheel Drive Low (4 ( n )
    setting.
    { Warning
    Shifting a four-wheel-drive
    vehicle's transfer case into
    N (Neutral) can cause the vehicle
    to roll even if the transmission is
    in P (Park). You or others could
    be injured. Set the parking brake
    before shifting the transfer case
    to N (Neutral).
    To dinghy tow:
    1. Position the vehicle being
    towed behind the tow vehicle,
    facing forward and on a level
    surface.
    2. Securely attach the vehicle
    being towed to the tow vehicle.
    3. Apply the parking brake and
    start the engine.
    4. Shift the transfer case to
    N (Neutral). See “Shifting into
    N (Neutral)” under Four-Wheel
    Drive 0 231. Check that the
    vehicle is in N (Neutral) by
    shifting the transmission to
    R (Reverse) and then to D
    (Drive). There should be no
    movement of the vehicle while
    shifting.
    5. Turn the engine off.
    Caution
    Failure to disconnect the negative
    battery cable or to have it contact
    the terminals can cause damage
    to the vehicle.
    6. Disconnect the negative
    battery cable at the battery and
    secure the nut and bolt. Cover
    the negative battery post with a
    non-conductive material to
    prevent any contact with the
    negative battery terminal.
    7. Shift the transmission to
    P (Park).
    Caution
    If the steering column is locked,
    vehicle damage may occur.
    8. Move the steering wheel to
    make sure the steering column
    is unlocked.
    9. With a foot on the brake pedal,
    release the parking brake.
    Keep the ignition key in the
    towed vehicle in ACC/
    ACCESSORY to prevent the
    steering column from locking.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 27, 2026
