fla_hobo's avatar
fla_hobo
flat towing a toad
We have just purchased a motor home and are doing a lot of research on which vehicles are the easiest and best to tow flat behind.
We are wanting a suv type as its not so low to the ground & better fuel mileage.
Please wed like to learn form the experts on the road not what the salesmen say.
We have been Rvers full time for over 20 years with a 40' 5th.
2001 Holiday Rambler
  • I have a 2011 Fusion Hybrid that I flat tow and just bought a 2020 Escape Hybrid that I will set up to flat tow. I believe that most hybrids are flat towable and I know that the 2 I have are easy to tow.
  • If you want a decent inexpensive vehicle to tow, that can carry quite a few people, pets, or supplies, a 2006-2011 Chevrolet HHR is a great toad. They can be towed 4 down with an automatic transmission and all you have to do is pull one fuse. I installed a switch to bypass the fuse when I tow. All it takes is a light kit and a tow bracket and you are good to go. I had diodes installed on mine so it just uses the existing tail lights and brake lights. It is very light so you don't really know it is back there.
  • We have towed a lot of Jeeps and all worked well. A Colorado or Ranger would work too.
  • Try to avoid as many of the add ons as possible to make a vehicle towable: ie: drive shaft disconnects, lube pumps, etc.
    If you desire an automatic transmission you will likely have to go with a 4wd vehicle. Jeep models have worked very well for us over the years. Models like the Liberty, and Grand Cherokee.
Looking for advice before your next adventure? Look no further.25,130 PostsLatest Activity: May 01, 2025
