bshpilot
Jul 11, 2014Explorer
MonroeJim wrote:
I'm considering towing a Jeep Wrangler 2014 with manual transmission and 4-wheel drive. I read on-line of earlier Wranglers engaging in gear while being towed causing an accident. Is this an actual problem with later wranglers?
Any other problems experienced in towing later model wranglers with manual/4 wheel drive? Many thanks.
WELCOME to THE FORUM !!!
ALL 4wd wranglers have MANUAL transfer cases...even the top of the line loaded w/ everything automatics.
The 2014 wrangler will tow fine, automatic or manual.
I tow a MANUAL transmission '12 Wrangler Sport & the procedure is EXACTLY the same.
There is no risk or reason why a manual transmission placed in gear would cause an accident. the procedure from Mopar is to place the transfer case in neutral and then place the (manual) transmission in some gear.
Jeep want the transmission in A gear to put some tension on the gear box & eliminate parasitic drag on the gear set (imo).
Heres the text from the actual jeep wrangler manual -
2010+ jeep wranglers do NOT require a key in the ignition, turned on, or a fuse pulled (to prevent battery drain while the key is on) - since there is NO Steering wheel lock.
You can review & verify the exact procedure for a 2014 in their on-line owners manual - it has not changed 2014 Owners Manual Link
Looking for advice before your next adventure? Look no further.25,194 PostsLatest Activity: Apr 29, 2026
