dodge_guy
Feb 20, 2020Explorer II
You can't only disconnect the rear driveshaft and not the front. With only the front driveshaft turning there is no way to lube the t-case because the pump is driven off the chain the is driven off the output shaft of the case. The trans may not be damaged but the t-case will be.
Maybe put 2 disconnects in?
The only other solution is to get a vehicle that is towable 4 down.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 17, 2026
