SuperBus's avatar
Feb 20, 2020
Flat Towing Lincoln Navigator with Driveshaft Disconnect
Hello,
I'd like to see if anyone is flat towing a 2015 - 2017 Lincoln Navigator (previous generation) or its sister, the Expedition using a driveshaft disconnect. We purchased ours (MY2017) before we bought our coach last year. As equipped, it is not flat towable as the transfer case does not have a neutral position. I recently recalled that Superior Driveline makes a driveshaft disconnect and spoke with one of their specialist relating to my application. I was told, and it seems reasonable, that since I do have an actual 2H position in the t-case that disconnecting the rear driveshaft with their product would be a viable solution to my problem. Working in the automotive industry I will also reach out to my contacts at Ford, but I am also curious if anyone has done this already without (or with!) issues.
As I can anticipate some "helpful" responses, please note I will not be selling it and am also in the midst of purchasing another vehicle which for darn sure will be flat towable. It would just be nice to also have the utility and size of the Navigator available with us on trips where it would be needed, or at least desirable, as the next vehicle doesn't "need" to be a another full size SUV. That would just be irresponsible ;)
Thanks!
  • twodownzero wrote:
    There are no Lincoln Navigators with "freewheeling" front hubs, so if that is your concern, then you might as well not worry about that.
    Front-hub actuation is vacuum controlled by a solenoid commanded by the PCM. While the SuperDuty trucks are normally disengaged, and use vacuum to engage them (with a manual override), the light-duty Ford trucks are normally engaged, and uses vacuum to disengage. This way you still have 4x4 in case of a vacuum leak, since there's no manual override.
    If you're thinking the Navigator has fixed front hubs, that is incorrect.
    If you have a Navigator with the 2-speed Transfer Case, Neutral Towing is built-in feature, and it disengages the front hubs when the T-Case is placed in that mode. Prior to this being a built-in factory option, Ford sold a "Neutral Tow kit" so you could manually disengage the front hubs by means of a 2nd downstream solenoid.
    With the factory flat-tow configuration, in there event vacuum did leak and the hubs did engage, if wouldn't matter because the T-Case would still get lubrication from the rear drive-line spinning. This would not be the case using a driveline disconnect.
    FWIW -
    Navigator Neutral Tow Procedure
  • Ford puts out a yearly Towing Guide that also list Lincoln. search by the year of your vehicle and Ford RV and trailer guide. Info is very useful.
  • According to the systems engineer I spoke with at Ford and a colleague of mine in the driveline supplier industry, the REMCO DSC should be a suitable way to make the Lincoln flat-towable. The engineers couldn't see a way it would be harmful to the vehicle, nor really any different than driving it down the road, so long as the t-case was in 4x2 and the transmission was in neutral, AND of course the rear driveshaft was disconnected. Depending on what other vehicle we purchase, we may end up installing the DSC and trying the flat tow this summer. I'll revisit this post and provide an update if I install one and let you all know how it worked out.
