armyhockeynut's avatar
Feb 29, 2016
Flat towing with a 3rd row?
Looking for a vehicle with 3rd row seating that we can tow flat. I am not interested in any of the big SUVs that have this, something more mid-size? Any suggestions?
Still have a TT, but will be moving up to a motorhome at some point soon and want to be ready with a car we can tow...
  • Jeep Commander and the current generation Dodge Durango (both based on the Grand Cherokee) have third row options and should be flat towable in 4WD trim, if they have the low range transfer case with neutral. There were AWD options without low range that are not flat towable, so you need to check and make sure it has a neutral position.
  • We have a Ford Freestyle (now the Taurus) with 3rd row seating for a total of 7. Volvo XC also has 3rd row seating as well as those mentioned already.
  • Chevy Traverse, Buick Enclave, GMC Acadia I believe all have third row seating options. Don't know about towability of current models.
  • Ford Flex is what we tow. But it is not a mid size vehicle..
  • Personally, I do not know of any 8 to 9 passenger vehicles that meet your specifications. AFAIK, "big SUVs" are the only ones. In order to be towable, it will likely have to be four wheel drive, with a NEUTRAL position on the transfer case shift. It is, however, possible a lube pump can be installed to lube/cool the transmission ($1000, more or less). Such a rig will be fairly heavy, quite possibly in excess of 5000 lbs(especially if a lot of "stuff" is carried in it).
    Motorhomes normally have a towing capacity of 3500, 5000, or 10,000 lbs. The 10K towing capacity is, in my experience, usually only found in high end diesel pusher coaches.
    Good luck in your search.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
