plunkettlb's avatar
plunkettlb
flat towing
I am looking into leasing a 2013 Honda fit, can they be flat towed, Remco towing says you can flat tow the fit, but they also officially say from Remco and Honda that they cannot be, Which do you believe.
  • I thought I remembered reading someplace that you couldn't even put a receiver on the back of a leased vehicle, unless it came with one. I guess that would constitute changing the vehicle too.
    bumpy
  • RESEARCH what cars can be towed 4-down. There are quite a few out there. Don't limit your RESEARCH to "new". Good used cars are out there that can be towed 4 down. So far,my first toad was a used '96 Ford Contour, 5 speed stick. Put that in neutral and go. My next toad was a new 2007 Chevy HHR automatic. Pull a fuse and off y'go. I also toad a (new) 2011 Ford Ranger 4WD automatic. A bit more $$ to set up for towing, but, for me, worth it.
    As far as I know, a leased vehicle is limited to milage and woe be to you if you even change the radio! I strongly suggest you BUY. Then it's yours and no worries about "changing" anything.
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 17, 2025
