huntram
Sep 26, 2013Explorer
Larry,
I'm glad you felt comfortable using a hair dryer. I did not. I just wanted to give an alternative to those that had the same issue as me.
My freezer does not have any ice on the shelve or on the sides. Just on the back. Others may be different. The other thing I found when melting the ice is:
1. I never felt good about scrapping the walls of the freezer even with the plastic spatula.
2. It always made an icy mess. It took awhile to clean and dry the ice on the bottom as it fell and melted off.
With the sheets it comes off in two easy sheets, no fuss, no muss. Please do not do this if you are happy with the hair dryer method, but I can tell you that it was the easiest way that you will EVER do if you try it!
God Bless,
Brian
God Bless,
Brian
Looking for advice before your next adventure? Look no further.25,191 PostsLatest Activity: Apr 04, 2026
