LarryJM
Sep 27, 2013Explorer II
huntram wrote:
Larry,
I'm glad you felt comfortable using a hair dryer. I did not. I just wanted to give an alternative to those that had the same issue as me.
My freezer does not have any ice on the shelve or on the sides. Just on the back. Others may be different. The other thing I found when melting the ice is:
1. I never felt good about scrapping the walls of the freezer even with the plastic spatula.
2. It always made an icy mess. It took awhile to clean and dry the ice on the bottom as it fell and melted off.
With the sheets it comes off in two easy sheets, no fuss, no muss. Please do not do this if you are happy with the hair dryer method, but I can tell you that it was the easiest way that you will EVER do if you try it!
God Bless,
Brian
I understand and one thing that jumped out at me is that if you had an inch of ice on the back wall something IMO is wrong since even after about 3 weeks to 1 mo I have never had any more that less than the thickness of a penny of ice on the back wall. Usually it's just a very thin layer with some loose frost on top of that which comes off easily with one swipe of the plastic spatula. I wonder if those sheets actually promote more ice accumulation than normal since an inch of ice is HUGE.
I always put a towel in the bottom of the freezer when defrosting so 90% of the ice ends up on the towel and when the ice is off I just fold the towel up and almost all the ice and the majority of the water that has melted which is minimal goes with it. It generally takes me as long to empty and restock the freezer as it does to defrost it.
I can understand the reluctance of using things like hair dryers and plastic spatulas, but there is not much you can really damage unless you put concentrated heat on one section enough to "debond" the cooling coils to the cooling plate which is really sort of hard to do. I only use a hair dryer since we always have one available and it's just the most convenient thing to use. As I said the idea is to put warm air circulating inside the freezer to defrost it as quick as possible and a hair dryer provides that with considerable force to do the job quickly as long as you use a few precautions.
Larry
Looking for advice before your next adventure? Look no further.25,191 PostsLatest Activity: Apr 04, 2026
